Does anybody unkown philco?
The chassis is a 95.
The cabinet is a Philco Highboy:
http://www.philcoradio.com/gallery/1929c.htm#e
The grille insert is, most likely, not original. Notice how it is offset to the right and is also just a bit too wide (top to bottom) for the opening? I would bet it was installed later by someone who wanted something that looked a bit more decorative than the typical tapestry grille cloth, which may have become damaged prompting this addition.
Does anybody unkown philco? - by Fred Taylor - 01-12-2015, 08:36 PM
RE: Does anybody unkown philco? - by Ron Ramirez - 01-12-2015, 10:43 PM
RE: Does anybody unkown philco? - by Fred Taylor - 01-12-2015, 10:56 PM
RE: Does anybody unkown philco? - by Ron Ramirez - 01-12-2015, 11:00 PM
RE: Does anybody unkown philco? - by Fred Taylor - 01-12-2015, 11:27 PM
RE: Does anybody unkown philco? - by Arran - 01-13-2015, 02:03 AM
RE: Does anybody unkown philco? - by DeckApe - 01-23-2015, 02:11 PM
RE: Does anybody unkown philco? - by Fred Taylor - 02-04-2015, 10:44 PM
RE: Does anybody unkown philco? - by DeckApe - 02-05-2015, 10:30 AM
RE: Does anybody unkown philco? - by Joe Rossi - 02-02-2015, 10:03 AM
There are currently 2702 online users. [Complete List]
» 2 Member(s) | 2700 Guest(s)
