Radio Newbie in need of some guidance for an 84
#48
The connection point from the CT (-Icon_cool to the chassis ground measures 308ohms.
Testing the transformer as requested, shows all open from every wire to the transformer frame.
The only thing I see wrong with the transformer ( after learning a bunch here) is that I do not have exact balance on either side of the CT. 200ohms and 216ohms seem to not be normal I think.
Here is my chassis. Keep in mind I have to install the transformer, and the Electrolytic Caps yet and replace the two resistors that were wrong. The black wire you see near the power cord is just floating in the air. That is where I attach the negative ends of the Electolytics.
https://pbs.twimg.com/media/B7Rf-UiCEAEKcay.jpg:large
Philco 84 - by rciancia - 01-07-2015, 09:18 PM
RE: Radio Newbie in need of some guidance for an 84 - by rciancia - 01-13-2015, 09:19 PM
RE: Philco 84 - by KCMike - 01-07-2015, 11:22 PM
RE: Philco 84 - by BrendaAnnD - 01-07-2015, 11:53 PM
RE: Philco 84 - by morzh - 01-08-2015, 12:36 AM
