Another project - Philco Tropic 42-788
I worked on it a little more this evening. All IF transformers and the audio output transformer have now been removed.
The IFs will receive new wires.
The audio transformer...it was removed in order to give me a little more room to work - its wires were getting in the way.
Slow going...but making progress...
RE: Another project - Philco Tropic 42-788 - by Ron Ramirez - 01-13-2015, 10:50 PM
