Radio Newbie in need of some guidance for an 84
#52
Couple more questions.
What do you have for test equipment? Just a meter or do you have more? There are a few longshot tests we could try depending on what you have at your disposal. One thing you could do is check the tubes looking for a short between the big fat pins and the skinny pins. That might find a short in a tube.
Where on the earth are you? It is possible there may be someone here close by that can come over and help you troubleshoot this.
WE WILL FIX THIS. It just takes longer over the internet. Icon_smile
John
Las Vegas, NV USA
Philco 84 - by rciancia - 01-07-2015, 09:18 PM
RE: Radio Newbie in need of some guidance for an 84 - by LASJayhawk - 01-14-2015, 12:26 AM
RE: Philco 84 - by KCMike - 01-07-2015, 11:22 PM
RE: Philco 84 - by BrendaAnnD - 01-07-2015, 11:53 PM
RE: Philco 84 - by morzh - 01-08-2015, 12:36 AM
