Philco 19H weak/no reception
Hello, changing to a 10k didn't work. Actually I put a pot in there and had it all over to see if I could find its sweet spot, no luck. I will try a different tube. I did see there is a 36A in the set vs. a 36, I see it is a suitable sub, anyone have any experience with that? Thanks for the help!
Philco 19H weak/no reception - by jeffb - 01-13-2015, 09:51 PM
RE: Philco 19H weak/no reception - by morzh - 01-13-2015, 10:23 PM
RE: Philco 19H weak/no reception - by jeffb - 01-13-2015, 10:27 PM
RE: Philco 19H weak/no reception - by morzh - 01-13-2015, 10:25 PM
RE: Philco 19H weak/no reception - by jeffb - 01-13-2015, 11:06 PM
RE: Philco 19H weak/no reception - by morzh - 01-13-2015, 11:14 PM
RE: Philco 19H weak/no reception - by jeffb - 01-14-2015, 08:14 AM
RE: Philco 19H weak/no reception - by morzh - 01-14-2015, 01:14 PM
RE: Philco 19H weak/no reception - by jeffb - 01-14-2015, 05:21 PM
RE: Philco 19H weak/no reception - by morzh - 01-15-2015, 12:13 AM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 08:27 AM
RE: Philco 19H weak/no reception - by Ron Ramirez - 01-15-2015, 12:18 PM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 12:50 PM
RE: Philco 19H weak/no reception - by Ron Ramirez - 01-15-2015, 12:58 PM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 01:11 PM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 07:14 PM
RE: Philco 19H weak/no reception - by morzh - 01-15-2015, 07:24 PM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 07:32 PM
RE: Philco 19H weak/no reception - by jeffb - 01-18-2015, 05:51 PM
RE: Philco 19H weak/no reception - by Arran - 01-20-2015, 04:39 AM
RE: Philco 19H weak/no reception - by morzh - 01-18-2015, 08:44 PM
RE: Philco 19H weak/no reception - by PAradiogeek - 01-19-2015, 10:16 PM
RE: Philco 19H weak/no reception - by jeffb - 01-20-2015, 07:50 AM
There are currently 9392 online users. [Complete List]
» 3 Member(s) | 9389 Guest(s)
