Another project - Philco Tropic 42-788
More progress:
[Image: http://www.philcoradio.com/images/phorum...88_014.jpg]
Finally, I am getting to the point that I have replaced almost all of the old wiring with rotten rubber insulation. I've removed both electrolytics and will attempt to restuff them. I still have some components to replace in the vicinity of the volume and tone controls as well as the first audio amp.
I knew this would be difficult. And it certainly has been!
RE: Another project - Philco Tropic 42-788 - by Ron Ramirez - 01-16-2015, 10:06 PM
