46 FADA completed
I ran an extensive thread on the alternate forum while working on this radio for a year.  It is finally completed and though some of you here might like to look at some pictures.  I can't take credit for the cabinet work which was done by my friend Ray.  The final putting everything together was my friend Mark.  I spent most of the year working through the pot metal and getting the chassis to work.  The outcome I think is very nice!
[Image: http://i303.photobucket.com/albums/nn129...A46001.jpg]
[Image: http://i303.photobucket.com/albums/nn129...A46002.jpg]
46 FADA completed - by jerryhawthorne - 01-17-2015, 01:32 AM
RE: 46 FADA completed - by sam - 01-17-2015, 02:39 AM
RE: 46 FADA completed - by OldRestorer - 01-17-2015, 09:07 AM
RE: 46 FADA completed - by klondike98 - 01-17-2015, 10:07 AM
RE: 46 FADA completed - by Eliot Ness - 01-17-2015, 11:14 AM
RE: 46 FADA completed - by morzh - 01-17-2015, 01:01 PM
RE: 46 FADA completed - by jerryhawthorne - 01-18-2015, 06:04 PM
RE: 46 FADA completed - by KCMike - 01-18-2015, 07:37 PM
RE: 46 FADA completed - by sam - 01-18-2015, 07:58 PM
RE: 46 FADA completed - by codefox1 - 01-18-2015, 09:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
