37-675 Dial Replacement Phantom Gasket
Got a dial replacement from Radio Daze.  I'm putting it on now, and mind you. it was disassembled about 3 years ago.
No...I didn't take pictures!  Icon_evil   Anywho, here's the gasket in question:
Does this even belong to this radio?  Icon_crazy   For the life of me, I see no way it'll fit.  I have downloaded service bulletins, probably from Chuck's site, and there's no mention of it.
The dial looks nice, but it's a tight fit onto the housing.  Actually, I'm afraid I'll crack it!  I took the ID, of the original dial, and it's a tight fit too!  Maybe I'll put a dab of Vaseline on it, before attempting again!  Any suggestion here?
Thanks for your help!
-Greg
37-675 Dial Replacement Phantom Gasket - by gvel - 01-17-2015, 05:20 PM
There are currently 10507 online users. [Complete List]
» 2 Member(s) | 10505 Guest(s)
