Philco 19H weak/no reception
Hi everyone, great news! The radio is alive and well. I tried 2 different good tubes and went with the one that worked best. However, either of the two good tubes did not like lowering the oscillator resistor down to 10kohms, so I left the 15k in there. I actually put a pot in the circuit to find its "sweet spot" with both tubes and it liked the 15 k ohms best. I don't care, it works great now, now to add the MP3/ I pod jack so I can listen to old radio shows. I put in the 1/8" audio jack on the ungrounded end of the volume control. It works, but there is some bleedthrough from the am dial. I built an audio isolation transformer from the Radio Shack plans ( I forget where I saw that) but need an adapter to go from the rca jack to the 1/8" audio. Thanks to all for your help here. PS- I just bought another Philco 19 cathedral yesterday!! That one is now on my long list!!
Philco 19H weak/no reception - by jeffb - 01-13-2015, 09:51 PM
RE: Philco 19H weak/no reception - by morzh - 01-13-2015, 10:23 PM
RE: Philco 19H weak/no reception - by jeffb - 01-13-2015, 10:27 PM
RE: Philco 19H weak/no reception - by morzh - 01-13-2015, 10:25 PM
RE: Philco 19H weak/no reception - by jeffb - 01-13-2015, 11:06 PM
RE: Philco 19H weak/no reception - by morzh - 01-13-2015, 11:14 PM
RE: Philco 19H weak/no reception - by jeffb - 01-14-2015, 08:14 AM
RE: Philco 19H weak/no reception - by morzh - 01-14-2015, 01:14 PM
RE: Philco 19H weak/no reception - by jeffb - 01-14-2015, 05:21 PM
RE: Philco 19H weak/no reception - by morzh - 01-15-2015, 12:13 AM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 08:27 AM
RE: Philco 19H weak/no reception - by Ron Ramirez - 01-15-2015, 12:18 PM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 12:50 PM
RE: Philco 19H weak/no reception - by Ron Ramirez - 01-15-2015, 12:58 PM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 01:11 PM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 07:14 PM
RE: Philco 19H weak/no reception - by morzh - 01-15-2015, 07:24 PM
RE: Philco 19H weak/no reception - by jeffb - 01-15-2015, 07:32 PM
RE: Philco 19H weak/no reception - by jeffb - 01-18-2015, 05:51 PM
RE: Philco 19H weak/no reception - by Arran - 01-20-2015, 04:39 AM
RE: Philco 19H weak/no reception - by morzh - 01-18-2015, 08:44 PM
RE: Philco 19H weak/no reception - by PAradiogeek - 01-19-2015, 10:16 PM
RE: Philco 19H weak/no reception - by jeffb - 01-20-2015, 07:50 AM
