Atwater Kent 55C - she's singing again
Recapping has gone smoothly although as the Pa Dutch would say the "quality condenser" is yet. (as in not yet done)
Unfortunately it turns out that 3 of the wire wound resistors are faulty (not uncommon I understand) since they are wound on cardboard or fiber board and are rather fragile.  They are the Bleeder Resistors #1 (4000 ohms) and #2 (850 ohms) and the RF Bias Resistor (160 ohms).
[Image: https://www.dropbox.com/s/xg0qyxpgow3tw3....jpg?raw=1]
[Image: https://www.dropbox.com/s/5u8h70k96ett7b....jpg?raw=1]
So unless I get really lucky and find some replacements I'm going to have to use modern replacements.  So here's the question:
Am I correct in figuring that 2 or 3 watt replacements would work OK?
My thinking:
 175 v (present @ plates of 1R and 2R) across 11,000 ohms (4000+6000+850+160) yields 0.016 amps.
(4000/11000)175 x 0.016 = 1.02 watts for the 4000 ohm resistor
double or triple that = 2 to 3 watts.  Similarly the other 2 resistors would be less wattage.
If I'm doing this calc wrong please let me know.... thanks for the help!!
(images are from Leigh's atwaterkent.info site )
RE: Atwater Kent 55C in Kiel Table - by sam - 11-25-2014, 01:17 PM
RE: Atwater Kent 55C in Kiel Table - by KCMike - 11-25-2014, 04:51 PM
RE: Atwater Kent 55C in Kiel Table - by Jayce - 11-26-2014, 02:03 PM
RE: Atwater Kent 55C in Kiel Table - by radioalfa - 11-26-2014, 11:05 PM
RE: Atwater Kent 55C in Kiel Table - by klondike98 - 01-20-2015, 03:06 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
