0.00011 mf caps in bakelite blocks
Just ordered up some 110pf caps so i should be good until I tackle THE BEAST my 38-116. After the 38-2, i
would hope things will be easier,still will be a challenge I know. Icon_thumbup but I'm up for it.
0.00011 mf caps in bakelite blocks - by Kestas - 12-09-2014, 05:19 PM
RE: 0.00011 mf caps in bakelite blocks - by morzh - 12-09-2014, 05:55 PM
RE: 0.00011 mf caps in bakelite blocks - by AI2V - 12-09-2014, 06:18 PM
RE: 0.00011 mf caps in bakelite blocks - by doug-5er - 01-20-2015, 11:19 PM
RE: 0.00011 mf caps in bakelite blocks - by morzh - 01-20-2015, 11:25 PM
