Another project - Philco Tropic 42-788
The next job was to disassemble each IF transformer, replace the wires, polish the cans, and reassemble.
Here is the 3rd IF transformer:
[Image: http://www.philcoradio.com/images/phorum...88_033.jpg]
All of the wires were replaced with new wires. The same procedure was performed on all three IF cans.
I now have a 1st IF transformer which is very similar to the original. It is a three-section IF which was pulled from a 38-1 console. (Thanks, Sam! Icon_thumbup )
My goal for this evening was to get all three rebuilt and bolted back onto the chassis. And I accomplished that goal.
[Image: http://www.philcoradio.com/images/phorum...88_034.jpg]
A closer look:
[Image: http://www.philcoradio.com/images/phorum...88_035.jpg]
No, they aren't wired in yet, but I will do that tomorrow.
Here's how they look above the chassis:
[Image: http://www.philcoradio.com/images/phorum...88_036.jpg]
[Image: http://www.philcoradio.com/images/phorum...88_037.jpg]
I think we're nearing the home stretch on this one.
RE: Another project - Philco Tropic 42-788 - by Ron Ramirez - 01-21-2015, 10:37 PM
