41-623 BOL and radio
Hi Ron,
 I just posted those to show you the unit.  I will post pics once I get it and clean it up a bit.  In a few weeks.  I will also post the 640 unit, the RP only, which works great now.  Thanks for the request.
41-623 BOL and radio - by davidff - 01-22-2015, 11:03 AM
RE: 41-623 BOL and radio - by Ron Ramirez - 01-22-2015, 12:30 PM
RE: 41-623 BOL and radio - by davidff - 01-22-2015, 01:30 PM
RE: 41-623 BOL and radio - by sam - 01-22-2015, 02:46 PM
RE: 41-623 BOL and radio - by davidff - 01-22-2015, 03:36 PM
RE: 41-623 BOL and radio - by davidff - 01-22-2015, 05:58 PM
RE: 41-623 BOL and radio - by Ron Ramirez - 01-22-2015, 06:59 PM
RE: 41-623 BOL and radio - by sam - 01-22-2015, 08:32 PM
RE: 41-623 BOL and radio - by NostalgiaRadioTime - 01-22-2015, 11:01 PM
RE: 41-623 BOL and radio - by davidff - 01-23-2015, 09:23 AM
RE: 41-623 BOL and radio - by sam - 04-14-2015, 11:47 AM
