Philco 511 Restoration - Advice ?
My original speaker worked for about a year then it started cutting out so I replaced it with a modern pm.
If you can align a tube radio, you can neutralize this one, after disabling the tube filament you adjust each section to the weakest signal rather than strongest as in alignment.
Philco 511 Restoration - Advice ? - by bdi1976 - 01-24-2015, 08:55 PM
RE: Philco 511 Restoration - Advice ? - by tab10672 - 01-25-2015, 02:52 AM
RE: Philco 511 Restoration - Advice ? - by Arran - 01-25-2015, 05:24 AM
RE: Philco 511 Restoration - Advice ? - by sam - 01-28-2015, 03:34 AM
