Schematic request-Philco 7030 signal tracer
Hi
I knew I had some info on Philco Test Equipment around here somewhere (with many thanks to Chuck who sent it to me in PDF format). Finally found it this morning...unfortunately, it only covers prewar Philco test equipment, and so it does not include your (postwar) 7030. Sorry about that.
Re: Schematic request-Philco 7030 signal tracer - by Ron Ramirez - 12-23-2008, 10:20 AM
There are currently 11365 online users. [Complete List]
» 2 Member(s) | 11363 Guest(s)
