40-165 Radiobar Zephyr restoration
Here are a few more pictures.  I made one modification that can be reversed in 5 minutes.  With a slight modification to the volume control I can play music via bluethooth and when unplugged it reverses to stock mode.  I followed this thread for the modification mp3 adapter .  Here's a before photo of the radio.  I think the previous repairman changed the filter capacitors before he realized the speaker was missing the cone.  After realizing he needed a new speaker I think he gave up.
Here it is before
after
modification
Keith
RE: 40-165 Radiobar Zephyr restoration - by keith49vj3 - 01-25-2015, 08:20 PM
RE: 40-165 Radiobar Zephyr restoration - by sam - 01-25-2015, 08:27 PM
There are currently 7716 online users. [Complete List]
» 2 Member(s) | 7714 Guest(s)
