pioneer sx1500td blowing fuse
Threads: 69
City: Kansas city, MO.
Yes I got them from mouser.Mouser Part #:
652-3352P-1-500LF . 50/ohms. The problem is they are not like pic. The adjustment is on top not at 90 degree so you can't get to it with amp in chassis. I ordered two more along with the 100k pots and will do them all and then install the amp.
RE: pioneer sx1500td blowing fuse - by KCMike - 01-26-2015, 06:15 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
