Finishing up my 41-280
It looks good.  You did a nice job cleaning and straightening the brass strip on the faceplate.
Finishing up my 41-280 - by K7Sparky - 01-27-2015, 08:04 PM
RE: Finishing up my 41-280 - by morzh - 01-27-2015, 08:13 PM
RE: Finishing up my 41-280 - by Eliot Ness - 01-27-2015, 08:15 PM
RE: Finishing up my 41-280 - by klondike98 - 01-27-2015, 08:31 PM
RE: Finishing up my 41-280 - by K7Sparky - 01-28-2015, 01:08 PM
RE: Finishing up my 41-280 - by KCMike - 01-28-2015, 01:12 PM
There are currently 11408 online users. [Complete List]
» 2 Member(s) | 11406 Guest(s)
