41-280 power switch and finish up
I re-built one of those myself.  Not difficult.  Just careful
rivet removal and do it in a box to catch any springs
that may liberate themselves.
A little contact cleaner and like new.  Once I had to use a relay contact
burnishing tool to smooth out one contact.
Small switch, thick fingers makes it interesting.   Icon_biggrin
Chuck
41-280 power switch and finish up - by K7Sparky - 01-27-2015, 07:37 PM
RE: 41-280 power switch and finish up - by Chuck Schwark - 01-28-2015, 10:15 AM
RE: 41-280 power switch and finish up - by sam - 01-28-2015, 01:15 PM
RE: 41-280 power switch and finish up - by sam - 01-29-2015, 05:02 AM
