Philco's most expensive radio
Ron there is nothing wrong with being a "catfish" (bottom dweller) some radios with a little elbow grease turn out looking like the high dollar ones. Most I have paid is $190 for a 38-2 because it is a rarer set and I wanted it, should have done the buy it now and would have saved myself about 40 dollars. Click the link and it shows it before and during restoration.
Philco's most expensive radio - by Chris Drumma - 12-20-2005, 08:50 AM
[No subject] - by Ron Ramirez - 12-20-2005, 09:39 AM
[No subject] - by 49Stude63 - 12-20-2005, 01:36 PM
[No subject] - by Ron Ramirez - 12-21-2005, 09:09 PM
[No subject] - by Bill Hutchinson - 12-21-2005, 10:18 PM
[No subject] - by Terry Judkins - 12-22-2005, 10:49 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:06 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:17 PM
[No subject] - by Guest - 03-12-2006, 08:26 PM
Philco 91 Tuning Condenser
There are currently 9304 online users. [Complete List]
» 2 Member(s) | 9302 Guest(s)
