Philco 40-135
Ron probably knows the correct break points with relative rarity but my guess is "medium rare"
>20,000 produced fairly common
>10,000-20,000 medium rare
<10,000 pretty rare
Philco 40-135 - by Art Hoch - 01-30-2015, 11:56 PM
RE: Philco 40-135 - by klondike98 - 01-31-2015, 09:50 AM
RE: Philco 40-135 - by JimZ - 01-31-2015, 09:53 AM
RE: Philco 40-135 - by Ron Ramirez - 01-31-2015, 01:21 PM
RE: Philco 40-135 - by JimZ - 01-31-2015, 02:06 PM
There are currently 6488 online users. [Complete List]
» 2 Member(s) | 6486 Guest(s)
