Philco 40-135
JimZ has a good point...I would add that you probably don't see it mentioned much because it isn't a highly desirable radio. That doesn't make it bad...it just means that not a lot of collectors are knocking themselves out trying to get their hands on one.
Philco 40-135 - by Art Hoch - 01-30-2015, 11:56 PM
RE: Philco 40-135 - by klondike98 - 01-31-2015, 09:50 AM
RE: Philco 40-135 - by JimZ - 01-31-2015, 09:53 AM
RE: Philco 40-135 - by Ron Ramirez - 01-31-2015, 01:21 PM
RE: Philco 40-135 - by JimZ - 01-31-2015, 02:06 PM
There are currently 7844 online users. [Complete List]
» 3 Member(s) | 7841 Guest(s)
