Philco 42-395
I suppose it's a dumb statement, but is there a chance that Larry Bordonaro, in California makes that bezel? I assume it's plastic, like many of the '42 sets had. I'm sure that he has the one for the 42-355T, and bhe has done one or more models. He advertises in some of the radio antique mags (Antique Radio Monthly?). I have seen one of his bezels, and it's a knockout.
At first, I'd thought that the 42-395 was similar to the 42-400, but it's very different. I have a 42-400, and the bezel is metal. I'm junking a 42-1008, and that bezel is wood. They made them all sorts of ways.
Philco 42-395 - by Guest - 10-12-2008, 07:36 AM
RE: Philco 42-395 - by lasttoknow - 05-25-2012, 12:23 PM
Re: Philco 42-395 - by Ron Ramirez - 10-12-2008, 11:14 AM
Re: Philco 42-395 - by Guest - 10-12-2008, 12:40 PM
Re: Philco 42-395 - by Ron Ramirez - 10-13-2008, 07:09 PM
Re: Philco 42-395 - by Guest - 11-15-2008, 10:38 AM
Re: Philco 42-395 - by Ron Ramirez - 11-15-2008, 02:49 PM
Re: Philco 42-395 - by Guest - 11-15-2008, 03:32 PM
Re: Philco 42-395 - by Guest - 12-28-2008, 04:50 PM
Re: Philco 42-395 - by Doug Houston - 12-28-2008, 05:14 PM
Re: Philco 42-395 - by Guest - 12-28-2008, 06:16 PM
Re: Philco 42-395 - by 49Stude63 - 12-30-2008, 01:20 PM
Re: Philco 42-395 - by Guest - 12-30-2008, 02:06 PM
Re: Philco 42-395 - by 49Stude63 - 12-30-2008, 02:10 PM
Re: Philco 42-395 - by Guest - 12-30-2008, 02:25 PM
Philco 91 Tuning Condenser
There are currently 5821 online users. [Complete List]
» 3 Member(s) | 5818 Guest(s)
