Original or not????
Ok I got this in the mail and i think someone screwed with it.
There is paint splatter on the paper tags so I know it was touched but is the decal right? I have seen gold back and silver back decals.
I just cant figure it out.
Original or not???? - by OldRestorer - 02-02-2015, 10:29 PM
RE: Original or not???? - by OldRestorer - 02-02-2015, 11:24 PM
RE: Original or not???? - by KCMike - 02-02-2015, 11:34 PM
RE: Original or not???? - by Arran - 02-03-2015, 01:35 AM
RE: Original or not???? - by Ron Ramirez - 02-03-2015, 07:38 AM
RE: Original or not???? - by OldRestorer - 02-03-2015, 09:10 AM
RE: Original or not???? - by Ron Ramirez - 02-03-2015, 11:15 AM
RE: Original or not???? - by OldRestorer - 02-03-2015, 12:23 PM
There are currently 9784 online users. [Complete List]
» 3 Member(s) | 9781 Guest(s)
