Original or not????
Ok, Definitely not original paint but decal may be???
The finish is sprayed over the original and now there is a crack in the grill.
This guy really misrepresented it....
Original or not???? - by OldRestorer - 02-02-2015, 10:29 PM
RE: Original or not???? - by OldRestorer - 02-02-2015, 11:24 PM
RE: Original or not???? - by KCMike - 02-02-2015, 11:34 PM
RE: Original or not???? - by Arran - 02-03-2015, 01:35 AM
RE: Original or not???? - by Ron Ramirez - 02-03-2015, 07:38 AM
RE: Original or not???? - by OldRestorer - 02-03-2015, 09:10 AM
RE: Original or not???? - by Ron Ramirez - 02-03-2015, 11:15 AM
RE: Original or not???? - by OldRestorer - 02-03-2015, 12:23 PM
