Original or not????
Solid silver rectangle with black lettering.
I've never seen an actual set with a gold rectangle.
http://www.radiodaze.com/philco-6-decals/
Original or not???? - by OldRestorer - 02-02-2015, 10:29 PM
RE: Original or not???? - by OldRestorer - 02-02-2015, 11:24 PM
RE: Original or not???? - by KCMike - 02-02-2015, 11:34 PM
RE: Original or not???? - by Arran - 02-03-2015, 01:35 AM
RE: Original or not???? - by Ron Ramirez - 02-03-2015, 07:38 AM
RE: Original or not???? - by OldRestorer - 02-03-2015, 09:10 AM
RE: Original or not???? - by Ron Ramirez - 02-03-2015, 11:15 AM
RE: Original or not???? - by OldRestorer - 02-03-2015, 12:23 PM
There are currently 7749 online users. [Complete List]
» 2 Member(s) | 7747 Guest(s)
