model 42-1003 code 121 volume control
Thanks, that was my plan so will give it a try this eve and let You know how I fair. This forum is a great place to pick everyone's brain and the info is, as always, welcome. Being a newbie, all the input has been a great help. I felt as if I may have tackled a project that was way beyond my pay grade but all the info I received has been fantastic and appreciated.
RE: model 42-1003 code 121 volume control - by mountain man - 02-03-2015, 12:40 PM
