Radiola 50
Both chassis look untouched as far as I can tell. First, here is the IF chassis. Pretty simple underneath except for what looks like a capacitor can.
Next is the power supply. Three Rheostats? (Am I spelling that righ?) I knew there was one which seemed to act as a hum control, but three? What do they do? Nothing on the schematic I found mentions these, but it appears this is the way the 17 was built. All three are adjustable from the top, though you need a long shanked, skinny screw driver to reach the one.
Radiola 50 - by Jayce - 01-30-2015, 04:24 PM
RE: Radiola 50 - by Eliot Ness - 01-30-2015, 06:16 PM
RE: Radiola 50 - by Jayce - 02-02-2015, 05:30 PM
RE: Radiola 50 - by OldRestorer - 02-02-2015, 07:15 PM
RE: Radiola 50 - by Jayce - 02-02-2015, 07:37 PM
RE: Radiola 50 - by Joe Rossi - 02-02-2015, 07:17 PM
RE: Radiola 50 - by PAradiogeek - 02-02-2015, 08:47 PM
RE: Radiola 50 - by Jayce - 02-03-2015, 06:02 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
