Help reply basics on refinishing
Fred, you just type in the reply box like you normally would and the put the image below the text and then more text after the image.  For example it would look like this as you compose the post:
Hi I'm Fred...here are my pics showing process XYZ....
[img}https://dl.dropboxusercontent.com/u/54621529/Question.jpg[/img]
and that's how I did it....
(of course the } should really be a ] but if I did that it would not show up in the post so you could see it)
So the post would look like
[Image: https://dl.dropboxusercontent.com/u/5462...estion.jpg]
Help reply basics on refinishing - by Fred Taylor - 02-03-2015, 09:17 PM
RE: Help reply basics on refinishing - by klondike98 - 02-03-2015, 09:47 PM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2802 online users. [Complete List]
» 2 Member(s) | 2800 Guest(s)
