Unknown (To Me, At Least) Philco
I didn't mention it but you should not try to plug in the radio to play it unless you know its been serviced recently.  See Ron's comments on plugging it in.
RE: Unknown (To Me, At Least) Philco - by KCMike - 02-03-2015, 08:59 PM
RE: Unknown (To Me, At Least) Philco - by Arran - 02-04-2015, 04:19 AM
RE: Unknown (To Me, At Least) Philco - by klondike98 - 02-03-2015, 10:14 PM
There are currently 7795 online users. [Complete List]
» 3 Member(s) | 7792 Guest(s)
