Mucho Grill cloth!
Chevron in the 70/90?!? NO!!!
I gave you the wrong link, sorry. Here is the correct one (and I will also correct my post above):
http://www.radiodaze.com/grille-cloth-02-item-grc02/ OR
"Whiskey Rayon" from Richmond Designs. http://www.richmonddesignsinc.com/grille...oduct_page
NOTE: This also applies to your early model 60.
Mucho Grill cloth! - by OldRestorer - 02-04-2015, 12:54 AM
RE: Mucho Grill cloth! - by OldRestorer - 02-04-2015, 12:59 AM
RE: Mucho Grill cloth! - by sam - 02-04-2015, 04:45 AM
RE: Mucho Grill cloth! - by OldRestorer - 02-04-2015, 08:47 AM
RE: Mucho Grill cloth! - by klondike98 - 02-04-2015, 10:33 AM
RE: Mucho Grill cloth! - by Ron Ramirez - 02-04-2015, 10:33 AM
RE: Mucho Grill cloth! - by OldRestorer - 02-04-2015, 10:47 AM
RE: Mucho Grill cloth! - by Ron Ramirez - 02-04-2015, 10:57 AM
RE: Mucho Grill cloth! - by morzh - 02-04-2015, 02:23 PM
RE: Mucho Grill cloth! - by OldRestorer - 02-04-2015, 03:19 PM
