Philco model 37-610
Doug Houston Wrote:I gots a better idea. All of this sounds like you may not even have the correct chassis, though some "engineer" could have hacked the original chassis to pieces.
I have a couple of '37 chassis laying around here somewhere, and I could check to see if teither isthe right one. If one of them is, you can have it for the shipping. And also, I'd supply pictures just to let you see if you'd want it.
If the chassis you have is a butchered original chassis, and if what I have is restorable, you'd need to scramble parts between the two, and end up with the right electronics. E-mail me if yo're interested.
Doug: Yes, I would be very grateful if you did that. Thanks.....Phil Vanderoef
Philco model 37-610 - by phil vanderoef - 12-22-2008, 09:27 AM
Re: Philco model 37-610 - by AI2V - 12-22-2008, 10:55 AM
Re: Philco model 37-610 - by phil vanderoef - 12-22-2008, 12:05 PM
Re: Philco model 37-610 - by BDM - 12-22-2008, 02:48 PM
Re: Philco model 37-610 - by AI2V - 12-22-2008, 04:50 PM
Re: Philco model 37-610 - by BDM - 12-22-2008, 05:10 PM
Re: Philco model 37-610 - by phil vanderoef - 12-23-2008, 08:25 AM
Re: Philco model 37-610 - by Ron Ramirez - 12-23-2008, 09:31 AM
Re: Philco model 37-610 - by Doug Houston - 12-27-2008, 06:29 PM
Re: Philco model 37-610 - by phil vanderoef - 12-30-2008, 07:58 AM
Re: Philco model 37-610 - by phil vanderoef - 12-30-2008, 08:00 AM
Re: Philco model 37-610 - by Ron Ramirez - 12-30-2008, 07:55 PM
Re: Philco model 37-610 - by Doug Houston - 12-31-2008, 08:33 PM
Re: Philco model 37-610 - by Texasrocker - 12-31-2008, 11:05 PM
Philco 91 Tuning Condenser
