Shadow meter question
Your shadowmeter may be just fine. It sounds like there isn't much change in the AVC voltage, you may just need to use a longer antenna or the radio may need an alignment.
M R Radios   C M Tubes
Shadow meter question - by Diverted - 02-04-2015, 11:56 AM
RE: Shadow meter question - by klondike98 - 02-04-2015, 12:02 PM
RE: Shadow meter question - by Steve Davis - 02-04-2015, 12:22 PM
RE: Shadow meter question - by Diverted - 02-04-2015, 12:46 PM
RE: Shadow meter question - by Diverted - 02-04-2015, 04:28 PM
RE: Shadow meter question - by codefox1 - 02-04-2015, 05:22 PM
RE: Shadow meter question - by klondike98 - 02-04-2015, 07:04 PM
