  • 1 Vote(s) - 5 Average
So where should I start.... Philco 38-116
Bill, welcome. Many of us have restored radios like yours. As indicated, one little bit at a time. They are a little overwhelming when you look underneath. There are a fair number of radio geeks in AZ. Not certain of your exact location. Assuming (you know what that means) all the "iron" is good you probably need less than $50 in caps to get the radio playing and indeed they sound great. The key is to work slowly and ask questions here.
Best, Jerry
RE: So where should I start.... Philco 38-116 - by jerryhawthorne - 02-05-2015, 07:59 PM
