Installing a PM Speaker in a 38-7
Yup, and remember to also use the pole piece with the choke/field winding. Hope you have room for it.
Installing a PM Speaker in a 38-7 - by dmcraesho - 02-06-2015, 02:18 PM
RE: Installing a PM Speaker in a 38-7 - by morzh - 02-06-2015, 02:54 PM
RE: Installing a PM Speaker in a 38-7 - by codefox1 - 02-07-2015, 03:07 PM
