Concert Grand Alert
Miquelonbrad Wrote:I "reformed" the caps by slowly ramping up the voltage over several hours, and the radio does work, but it will require a tune-up. But that should be easy, as I don't think the chassis has been messed with. Very clean! Tubes still have the dealer decals on them, that match the dealer decal pasted on the back.
That radio did not use electrolytics, all of the caps in the large metal filter can are paper. Paper caps cannot be reformed.
Watch out! Paper caps can and will fail, also, with equally disastrous results. I once had a 96 that still worked, and so I played it...until one day I turned it on, I heard a loud hum and then smoke. Yup...shorted filter which took out the power transformer.
You really, really should replace ALL of the paper caps in that radio if you plan on using it. That is a fine piece of furniture and deserves no less.
Concert Grand Alert - by Ron Ramirez - 11-15-2008, 03:04 PM
Re: Concert Grand Alert - by Texasrocker - 11-15-2008, 11:37 PM
Re: Concert Grand Alert - by Ron Ramirez - 11-16-2008, 12:03 AM
Re: Concert Grand Alert - by FStephenMasek - 11-16-2008, 12:39 AM
Re: Concert Grand Alert - by Texasrocker - 11-16-2008, 01:51 AM
Re: Concert Grand Alert - by Ron Ramirez - 11-16-2008, 03:26 PM
Re: Concert Grand Alert - by Ron Ramirez - 11-18-2008, 09:16 PM
Re: Concert Grand Alert - by Texasrocker - 11-20-2008, 03:07 AM
Re: Concert Grand Alert - by DeckApe - 11-20-2008, 01:43 PM
Re: Concert Grand Alert - by Guest - 12-26-2008, 12:47 AM
Re: Concert Grand Alert - by Ron Ramirez - 12-26-2008, 12:44 PM
Re: Concert Grand Alert - by Guest - 12-31-2008, 12:01 AM
Re: Concert Grand Alert - by Arran - 12-31-2008, 12:45 AM
Re: Concert Grand Alert - by Ron Ramirez - 12-31-2008, 05:51 AM
Re: Concert Grand Alert - by Bill Cahill - 12-31-2008, 07:48 PM
Re: Concert Grand Alert - by Texasrocker - 12-31-2008, 11:32 PM
Re: Concert Grand Alert - by Arran - 01-01-2009, 02:24 AM
Re: Concert Grand Alert - by Guest - 01-05-2009, 09:28 PM
Re: Concert Grand Alert - by Ron Ramirez - 01-05-2009, 10:12 PM
Re: Concert Grand Alert - by Arran - 01-05-2009, 10:17 PM
There are currently 10305 online users. [Complete List]
» 2 Member(s) | 10303 Guest(s)
