Philco model 37-610
He's in luck. The chassis is totally intact, even to the bottom cover. No cream puff, but all there. This thing has been kicking around here for a couple of years, and now somebody can use it. A teeny bit of space cleared! Just shows to go ya, don't throw usable things out.
I see that the code 122 sets had the 5Y4 on the chassis, and not on the power transformer. I think that Jefferson Transformer built a lot, if not all, of Philco's transformers. Possibly, Philco could have gotten a sweet deal on a production run of conventional transformers?
Philco model 37-610 - by phil vanderoef - 12-22-2008, 09:27 AM
Re: Philco model 37-610 - by AI2V - 12-22-2008, 10:55 AM
Re: Philco model 37-610 - by phil vanderoef - 12-22-2008, 12:05 PM
Re: Philco model 37-610 - by BDM - 12-22-2008, 02:48 PM
Re: Philco model 37-610 - by AI2V - 12-22-2008, 04:50 PM
Re: Philco model 37-610 - by BDM - 12-22-2008, 05:10 PM
Re: Philco model 37-610 - by phil vanderoef - 12-23-2008, 08:25 AM
Re: Philco model 37-610 - by Ron Ramirez - 12-23-2008, 09:31 AM
Re: Philco model 37-610 - by Doug Houston - 12-27-2008, 06:29 PM
Re: Philco model 37-610 - by phil vanderoef - 12-30-2008, 07:58 AM
Re: Philco model 37-610 - by phil vanderoef - 12-30-2008, 08:00 AM
Re: Philco model 37-610 - by Ron Ramirez - 12-30-2008, 07:55 PM
Re: Philco model 37-610 - by Doug Houston - 12-31-2008, 08:33 PM
Re: Philco model 37-610 - by Texasrocker - 12-31-2008, 11:05 PM
There are currently 6941 online users. [Complete List]
» 2 Member(s) | 6939 Guest(s)
