Resistor replacement
Hello all,
  have read the phorum for quite a while but have never posted anything before.
Decided I need a little advice. I have restored and or worked on a fair amount of equipment over the years but am new to working on antique radios.
I am currently working on a 46-421. I have cleaned up the chassis, replaced all the caps and the power cord.
Now on to the resistors. I found three that are out of spec.
A 130, 470k, and 3.3M, this is where my questions come.
These all look to be carbon comp. resistors, should I replace with carbon comp. or go with something like flame-proof modern style resistors?
If flame-proof, should I use 1/2w or go up to 1w?
Any suggestions for a good place to buy new resistors that will work good on tube radios?
I'm having a hard time finding a 3.3M resistor. I don't want to solder resistors together to get the right value.
Thanks
RF
Resistor replacement - by RF7590 - 02-10-2015, 12:07 PM
RE: Resistor replacement - by morzh - 02-10-2015, 01:03 PM
RE: Resistor replacement - by codefox1 - 02-10-2015, 01:42 PM
RE: Resistor replacement - by klondike98 - 02-10-2015, 02:44 PM
RE: Resistor replacement - by RF7590 - 02-14-2015, 10:36 AM
RE: Resistor replacement - by OldRestorer - 02-14-2015, 10:43 AM
RE: Resistor replacement - by morzh - 02-14-2015, 12:42 PM
RE: Resistor replacement - by sam - 02-14-2015, 06:03 PM
RE: Resistor replacement - by morzh - 02-14-2015, 06:09 PM
RE: Resistor replacement - by markmokris - 03-10-2015, 08:21 AM
RE: Resistor replacement - by PAradiogeek - 03-10-2015, 09:26 AM
