Resistor replacement
1. Go with whatever the cheapes one you find, a metal film 5% is just fine.
2. No need for flame proof. If you get flames, you got worse problems, and adequately power rated resistor is all you need.
3. Calculate the wattage by U-square over R rule, you should know the dropout across the resistor. I use 1W for everything above 50K indiscriminately and for lower values I calculate the wattage.
4. It is rarely you need a resistor of 3.3M value to be very accurate. 10-20% is likely OK. However in Mouser there is plenty of 3.3M axials and one from Vishay 1/2W (which is plenty) is 13 cents stock.
Resistor replacement - by RF7590 - 02-10-2015, 12:07 PM
RE: Resistor replacement - by morzh - 02-10-2015, 01:03 PM
RE: Resistor replacement - by codefox1 - 02-10-2015, 01:42 PM
RE: Resistor replacement - by klondike98 - 02-10-2015, 02:44 PM
RE: Resistor replacement - by RF7590 - 02-14-2015, 10:36 AM
RE: Resistor replacement - by OldRestorer - 02-14-2015, 10:43 AM
RE: Resistor replacement - by morzh - 02-14-2015, 12:42 PM
RE: Resistor replacement - by sam - 02-14-2015, 06:03 PM
RE: Resistor replacement - by morzh - 02-14-2015, 06:09 PM
RE: Resistor replacement - by markmokris - 03-10-2015, 08:21 AM
RE: Resistor replacement - by PAradiogeek - 03-10-2015, 09:26 AM
There are currently 5022 online users. [Complete List]
» 1 Member(s) | 5021 Guest(s)
