Philco 41-100 Farm Radio
Hello All,
I'm restoring a Philco 41-100 Console Farm Battery Radio.
The wiring is toast right up to the transformer. I know I can heat shrink the bare wires, but was hoping someone would know a suitable replacement part. The drawing shows part number 32-8107, the actual number on the transformer is 7581 W-38560.
Also does anyone know someone who reproduces the dial scale for this model?
Philco 41-100 Farm Radio - by Lightnin - 02-10-2015, 03:49 PM
RE: Philco 41-100 Farm Radio - by jerryhawthorne - 02-10-2015, 04:02 PM
RE: Philco 41-100 Farm Radio - by klondike98 - 02-10-2015, 04:12 PM
RE: Philco 41-100 Farm Radio - by Lightnin - 02-10-2015, 04:51 PM
