Philco 41-100 Farm Radio
Thanks Jerry and Bob,
I already have the power source. I'm replacing wires and such no before applying power etc. I will check the transformer, but it seems I read an article they could be close to toast on the inside too even if the outer leads were sleeved.
Philco 41-100 Farm Radio - by Lightnin - 02-10-2015, 03:49 PM
RE: Philco 41-100 Farm Radio - by jerryhawthorne - 02-10-2015, 04:02 PM
RE: Philco 41-100 Farm Radio - by klondike98 - 02-10-2015, 04:12 PM
RE: Philco 41-100 Farm Radio - by Lightnin - 02-10-2015, 04:51 PM
