Unique idea for an antenna
You certainly need a cap. Make sure it is a Y-cap, as the voltage on a phone line can be 110V even though it is decoupled via a transformer, but then as usual you want to be sure that if it fails you are safe.
Some sort of a surge protection would not hurt, although I think phone lines use something like maybe gas discharge tubes arrestors.
Unique idea for an antenna - by 462ron - 02-10-2015, 04:07 PM
RE: Unique idea for an antenna - by Ron Ramirez - 02-10-2015, 05:35 PM
RE: Unique idea for an antenna - by morzh - 02-10-2015, 06:38 PM
RE: Unique idea for an antenna - by 462ron - 02-10-2015, 08:02 PM
RE: Unique idea for an antenna - by keith49vj3 - 02-12-2015, 08:04 PM
