Philco 37-630 questions
(02-11-2015, 03:17 PM)klondike98 Wrote:  Welcom to the Phorum!  There's a schematic on Audiophool's Philco page.  If you can't get the DJVU file to open let me know and I can post a pdf of it. Looks like the Tone Control is also the On-Off swithch (part #59).  Once turned on it appears further turning would adjust the tone by adding in different capacitors.  Perhaps someone with a 37-630 can say for certain.
Your best bet for a Philco replacement is to put an ad in the "Wanted Ads" section.
Hi Bob.
Could you please post the PDF? That file won't open for me.
Thank you
Joe
Philco 37-630 questions - by Ovila Joseph - 02-11-2015, 02:19 PM
RE: Philco 37-630 questions - by klondike98 - 02-27-2015, 10:42 AM
RE: Philco 37-630 questions - by Ovila Joseph - 02-27-2015, 07:33 PM
RE: Philco 37-630 questions - by klondike98 - 02-27-2015, 08:19 PM
RE: Philco 37-630 questions - by Ovila Joseph - 02-28-2015, 10:25 PM
RE: Philco 37-630 questions - by klondike98 - 03-01-2015, 05:16 PM
RE: Philco 37-630 questions - by Ron Ramirez - 03-02-2015, 08:41 AM
RE: Philco 37-630 questions - by mikethedruid - 08-15-2015, 07:48 PM
RE: potentiometer for a philco 37-630 - by Ovila Joseph - 02-11-2015, 10:11 PM
There are currently 5879 online users. [Complete List]
» 1 Member(s) | 5878 Guest(s)
