41-623 Rectifier
One of the 7B7 tube wont light and the XXD will not light.(both test good)   The other filaments, (not the 50Y6) all lite as well as the pilot lamp.  I will spray the tube sockets with deoxit and wiggle a bit.  I do not see any broken wires underneath.
41-623 Rectifier - by davidff - 02-12-2015, 10:23 AM
RE: 41-623 Rectifier - by morzh - 02-12-2015, 10:51 AM
RE: 41-623 Rectifier - by klondike98 - 02-12-2015, 11:00 AM
RE: 41-623 Rectifier - by morzh - 02-12-2015, 11:48 AM
RE: 41-623 Rectifier - by davidff - 02-12-2015, 03:39 PM
RE: 41-623 Rectifier - by klondike98 - 02-12-2015, 03:55 PM
RE: 41-623 Rectifier - by morzh - 02-12-2015, 03:59 PM
RE: 41-623 Rectifier - by davidff - 02-13-2015, 09:32 AM
There are currently 6082 online users. [Complete List]
» 1 Member(s) | 6081 Guest(s)
