41-623 Rectifier
OK, there has to be something causing an open in the filament series.  As morzh suggests try cleaning the tube sockets and I'd also resolder each of those connections in that series; perhaps there is a cold solder joint causing the problem.
41-623 Rectifier - by davidff - 02-12-2015, 10:23 AM
RE: 41-623 Rectifier - by morzh - 02-12-2015, 10:51 AM
RE: 41-623 Rectifier - by klondike98 - 02-12-2015, 11:00 AM
RE: 41-623 Rectifier - by morzh - 02-12-2015, 11:48 AM
RE: 41-623 Rectifier - by davidff - 02-12-2015, 03:39 PM
RE: 41-623 Rectifier - by klondike98 - 02-12-2015, 03:55 PM
RE: 41-623 Rectifier - by morzh - 02-12-2015, 03:59 PM
RE: 41-623 Rectifier - by davidff - 02-13-2015, 09:32 AM
