new here !!
It looks to be in wonderful condition.
http://www.nostalgiaair.org/PagesByModel...013467.pdf
Considering it was well kept, it might just so be that all you need a recap, and since farms do not need DC filter, the recap is easy.
Should you decide to proceed, folks here will guide you though.
new here !! - by jefferz940 - 02-12-2015, 04:37 PM
RE: new here !! - by morzh - 02-12-2015, 04:46 PM
RE: new here !! - by jefferz940 - 02-12-2015, 04:52 PM
RE: new here !! - by morzh - 02-12-2015, 04:57 PM
RE: new here !! - by jefferz940 - 02-12-2015, 05:08 PM
RE: new here !! - by klondike98 - 02-12-2015, 05:22 PM
RE: new here !! - by KCMike - 02-12-2015, 06:36 PM
RE: new here !! - by jefferz940 - 02-12-2015, 10:13 PM
RE: new here !! - by jefferz940 - 02-12-2015, 11:28 PM
RE: new here !! - by Arran - 02-13-2015, 12:25 AM
RE: new here !! - by sam - 02-13-2015, 05:11 AM
RE: new here !! - by jefferz940 - 02-13-2015, 10:55 AM
RE: new here !! - by klondike98 - 02-13-2015, 11:17 AM
RE: new here !! - by jefferz940 - 02-13-2015, 03:44 PM
RE: new here !! - by klondike98 - 02-13-2015, 05:07 PM
RE: new here !! - by PhilcoJohn - 02-13-2015, 08:07 PM
RE: new here !! - by jefferz940 - 02-13-2015, 08:41 PM
There are currently 7110 online users. [Complete List]
» 3 Member(s) | 7107 Guest(s)
