new here !!
Just saying welcome, and please heed advice to get help before proceeding.
Its easy to get impatient when you first start on one of these and want to get it playing. Good luck.
new here !! - by jefferz940 - 02-12-2015, 04:37 PM
RE: new here !! - by morzh - 02-12-2015, 04:46 PM
RE: new here !! - by jefferz940 - 02-12-2015, 04:52 PM
RE: new here !! - by morzh - 02-12-2015, 04:57 PM
RE: new here !! - by jefferz940 - 02-12-2015, 05:08 PM
RE: new here !! - by klondike98 - 02-12-2015, 05:22 PM
RE: new here !! - by KCMike - 02-12-2015, 06:36 PM
RE: new here !! - by jefferz940 - 02-12-2015, 10:13 PM
RE: new here !! - by jefferz940 - 02-12-2015, 11:28 PM
RE: new here !! - by Arran - 02-13-2015, 12:25 AM
RE: new here !! - by sam - 02-13-2015, 05:11 AM
RE: new here !! - by jefferz940 - 02-13-2015, 10:55 AM
RE: new here !! - by klondike98 - 02-13-2015, 11:17 AM
RE: new here !! - by jefferz940 - 02-13-2015, 03:44 PM
RE: new here !! - by klondike98 - 02-13-2015, 05:07 PM
RE: new here !! - by PhilcoJohn - 02-13-2015, 08:07 PM
RE: new here !! - by jefferz940 - 02-13-2015, 08:41 PM
There are currently 7640 online users. [Complete List]
» 2 Member(s) | 7638 Guest(s)
