Introduction and Radio Help
Phil, wow, that does sound great. Do you have other things that you collect? I am new to radios, so my collection is pretty small, but I come from a long line of antique hobbyists/collectors. Let me know if you have other interests or a price you would like for it. I'd be interested in working something out.
Introduction and Radio Help - by mikehorning - 12-30-2008, 07:06 PM
Re: Introduction and Radio Help - by Ron Ramirez - 12-30-2008, 07:47 PM
Re: Introduction and Radio Help - by mikehorning - 12-31-2008, 11:53 AM
Re: Introduction and Radio Help - by Steve Davis - 12-31-2008, 06:10 PM
Re: Introduction and Radio Help - by Ron Ramirez - 12-31-2008, 07:12 PM
Re: Introduction and Radio Help - by Ron Ramirez - 12-31-2008, 08:47 PM
Re: Introduction and Radio Help - by Texasrocker - 12-31-2008, 11:21 PM
Re: Introduction and Radio Help - by Uffda - 01-01-2009, 01:49 PM
Re: Introduction and Radio Help - by Ron Ramirez - 01-01-2009, 02:14 PM
Re: Introduction and Radio Help - by mikehorning - 01-01-2009, 06:07 PM
Re: Introduction and Radio Help - by mikehorning - 01-01-2009, 06:13 PM
Re: Introduction and Radio Help - by BDM - 01-01-2009, 07:33 PM
Re: Introduction and Radio Help - by Uffda - 01-01-2009, 09:10 PM
Re: Introduction and Radio Help - by Ron Ramirez - 01-01-2009, 11:01 PM
