Need place to repaint / restore a 513 cabinet
I tried to edit my post to add...Someone took a rattle can of spray paint and completely painted the entire cabinet a charcoal grey at some point in its life. There's no salvaging anything original about the paint because it simply doesn't exist.
RE: Need place to repaint / restore a 513 cabinet - by ProgressCity - 02-12-2015, 06:43 PM
There are currently 4578 online users. [Complete List]
» 2 Member(s) | 4576 Guest(s)
