Philco 41-240 Deaf on Shortwave
Thats also exactly the way my 42-327 did. I could pull the tube and stick it back in quickly and the shortwave would start. Couldn't duplicate the results from a cold start.
Loktal pins can be cantankerous and generally need cleaning with a fine abrasive (emery board, 400-600 sandpaper, etc). Regular electronics cleaner doesn't seem to do much good. The pins are some sort of aluminum alloy, iirc.
-Bill
Philco 41-240 Deaf on Shortwave - by canerods - 12-28-2008, 05:47 PM
Re: Philco 41-240 Deaf on Shortwave - by exray - 12-29-2008, 08:14 AM
Re: Philco 41-240 Deaf on Shortwave - by canerods - 12-29-2008, 08:35 PM
Re: Philco 41-240 Deaf on Shortwave - by canerods - 12-30-2008, 10:50 AM
Re: Philco 41-240 Deaf on Shortwave - by canerods - 12-30-2008, 06:05 PM
Re: Philco 41-240 Deaf on Shortwave - by canerods - 01-01-2009, 04:57 PM
Re: Philco 41-240 Deaf on Shortwave - by exray - 01-01-2009, 06:40 PM
Re: Philco 41-240 Deaf on Shortwave - by codefox1 - 01-02-2009, 06:41 PM
Re: Philco 41-240 Deaf on Shortwave - by canerods - 01-02-2009, 08:31 PM
There are currently 4941 online users. [Complete List]
» 3 Member(s) | 4938 Guest(s)
